Results 1 to 10 of 10
Thread: Longitudinal and Cross Power Feeds for G0602 Type Lathe
Hybrid View
    Quote Originally Posted by LMMasterMariner View Post
    I wasn’t happy with absence of power cross feed on my lathe, so decided to make one. ......... Other option was to install feed shaft. Didn’t even think of using DC motor and PWM controller like I did for power feed at my milling machine.
    Cheers
    LMMasterMariner
    OK I'll bite. Why did you not go for the motor option, something that you have had experience with? I would have thought fitting two motors would have been much less work.
  2. The Following User Says Thank You to tonyfoale For This Useful Post:
    Paul Jones (Feb 8, 2020)
    Jan 2016
    Dubrovnik - Croatia
    LMMasterMariner's Tools
    Two motors would be just a step towards CNC lathe which I don’t need. There are couple of CNC kits for this type of lathe on the market, but I wanted to make power feeds myself. Need lathe with all the features that good lathes have. Once I fabricate additional screw cutting gearbox (Norton type with only 7 gears inside gearbox) I will have the following feeds: Longitudinal: 0.059, 0.071, 0.083, 0.095, 0.106, 0.118, 0.142, 0.165, 0.177, 0.189, 0.213, 0.236, 0.295, 0.354, 0.413, 0.473, 0.591, 0.709, 0.827 mm and Cross: 0.008, 0.010, 0.012, 0.014, 0.015, 0.017, 0.020, 0.024, 0.025, 0.027, 0.030, 0.034, 0.042, 0.051, 0.059, 0.068, 0.084, 0.101, 0.118 mm and all metric threads from 0.25 to 3.5 mm without any gear change. There was an additional challenge; nobody did this kind of modification for this type of lathe so far. At least I can’t find any information about it. And yes, I agree with you that fitting two motors would require less work to do.
    Cheers
    LMMasterMariner
  4. The Following 2 Users Say Thank You to LMMasterMariner For This Useful Post:
    Canyonman44 (Feb 10, 2020), Paul Jones (Feb 8, 2020)
    Two motors would be just a step towards CNC lathe which I don’t need. ......
    .... And yes, I agree with you that fitting two motors would require less work to do.
    Cheers
    LMMasterMariner
    I had a chuckle when I read that. I was faced with that recently when my spindle drive modifications got in the way of re-installing the change gears. New feed drive method for a lathe. I kept thinking about motorising the feed, but like you I do not need a CNC lathe and it would have been impossible to resist the temptation to go all the way.
    Stockholm, Sweden...
    DIYSwede's Tools
    Absolutely right! YouTube is literally filled with fellow machinists merely doing what hundreds have already shared.
    Thanks for pioneering again into the hitherto unknown and uncharted realms of DIY!
    Respect
    Johan
  7. The Following User Says Thank You to DIYSwede For This Useful Post:
    mwmkravchenko (Feb 16, 2020)
    Supporting Member Canyonman44's Avatar
    Mar 2014
    Automatic feed/carriage stop
    I can't find part 2 of the vids. Do I take it it will come in May?? And do you happen to know how/if the G4003G differs from G0602? I have had the Grizz folks direct me towards the G0602 for parts. And I hate to ask, due to the time involved, will there be dimensioned plans? And what if I just want the automatic tool stop as mine has the feeds. I would be IMMENSELY interested in that!!!!! And I think I missed what activates the auto-stop?
    Thanks Ken
    Jan 2016
    Dubrovnik - Croatia
    Quote Originally Posted by Canyonman44 View Post
    Thanks Ken
    Part 2 should be completed latest by the end of May. Still have 2 months till end of my contract and expect to be home beginning April.
    As you can find in Grizzly adverts, G4003G is real machine allegedly the second G stands for gunsmithing and G0602 is much cheaper lathe but quite okay for hobby. Nothing needs to be modified on G4003G unlike G0602. Here I put one more drawing for clarification of automatic stop. When part called "AAA" come to carriage stop (of any kind, so many pictures on the web) and as carriage is progressing towards to the chuck, AAA as part of yellow painted flat bar is moving backwards and by doing that, it's moving the latch out of engagement. Latch was made from the key 15x10 mm, length 75 mm. Hope it's more clear now.
    Cheers
    LMMasterMariner
    Attached Thumbnails Attached Thumbnails Longitudinal and Cross Power Feeds for G0602 Type Lathe-a700-30-22-102.jpg   Longitudinal and Cross Power Feeds for G0602 Type Lathe-20191115_134501.jpg
  10. The Following 2 Users Say Thank You to LMMasterMariner For This Useful Post:
    Canyonman44 (Feb 10, 2020), mwmkravchenko (Feb 16, 2020)
  11. #7
    Mar 2014
    Forgive me, I'm not as sharp as I used to be. Would it be possible to superimpose the schematic over a picture of the apron/carriage? Just a request, you are not obligated to do anything. Ken
  12. #8
    Jan 2016
    Dubrovnik - Croatia
    as you wished. schematic over the picture. Hope you got it now. if not, i'm afraid that you will need to wait for part 2.
    Attached Thumbnails Attached Thumbnails Longitudinal and Cross Power Feeds for G0602 Type Lathe-vlcsnap-2020-02-06-16h01m40s56.jpg
  13. The Following User Says Thank You to LMMasterMariner For This Useful Post:
    Canyonman44 (Feb 13, 2020)
