Thread: Machining a 70 degree acute angle vee.
    Supporting Member Mook's Avatar
    Sep 2023
    UK
    Mook's Tools
    Machining acute angles less than 90 degrees can present problems as most cutters and grinding wheels have square corners.
    This is my method
    : I leave the block oversize, finish the vee, and then finish grinding the oversize block to the pin.
  2. The Following User Says Thank You to Mook For This Useful Post:
    Jon (Mar 31, 2025)
