Results 1 to 10 of 13
Thread: Made my engine hoist a little better.
Hybrid View
    Mar 2020
    I replaced the hydraulic jack with a battery powered linear actuator (3000 lbs. capacity). Raising and lowering the boom became a breeze.
  2. The Following User Says Thank You to mansworld For This Useful Post:
    emu roo (Sep 11, 2025)
    Quote Originally Posted by mansworld View Post
    That would be a great improvement but 3000 lbf would not be anywhere near enough for me. I will look for a bigger capacity.
  4. The Following User Says Thank You to tonyfoale For This Useful Post:
    Mar 2020
    I was referring to the 1.5 - 2 ton foldable engine hoist pictured in the subject. furthermore, 3000 bls. /1.5 ton was the biggest capacity battery powered linear actuator available at Amazon, and I doubt if you can get any larger capacity than that. One thing you do is to add extra actuators and join them in a group till you reach your target capacity.
  6. The Following User Says Thank You to mansworld For This Useful Post:
    The 1.5 - 2 ton is at the end of the boom. The actuation is way back from that and so through leverage you need several times 1.5 - 2 ton at the actuator to get 1.5 - 2 ton at the hook. Using a 3000 lbf actuator may give you a useful tool but it will not give you 3000 lbf where it matters.
  8. The Following User Says Thank You to tonyfoale For This Useful Post:
    Mar 2020
    A one good thing about linear actuators/ screw jacks, is that they are oil-leak free. I have 3 oil leaking hydraulic jacks on my repair shelf. There are screw jacks with a capacity of up to 200 ton, and travel length of 3.5 meter/ 138 inch. Screw jacks are often custom-made to meet specific application needs.
    Aug 2012
    Australia
    desbromilow's Tools
    just be aware that you've considerably reduced the capacity of the crane - most of the engine cranes use a 9T hydraulic ram, to alllow 2T at the short extension (no extension), and 500kg (1/2T) at max extension - by using a 3000lb ram, you've scaled your capacities by a similar factor (3,000lb is nearly 1.5T which is 1/6 of 9T, which means your capacity of no extension reduces from 2T to 2t/6, and your max extension capacity of 500kg (1/2T reduces to 1/2t divided by 1/6 = 1/12t which is about 80kg (call it 160 lbs)
