Results 1 to 10 of 20
Thread: Making a plumb bob
    Supporting Member Dimitris Polychronis's Avatar
    Nov 2018
    Athens-Greece
    Dimitris Polychronis's Tools
    Making a plumb bob
    Although that there are numerous digital tools for checking vertical alignment, a plumb bob still can be a very useful aid in the shop or home.
    I used 304 stainless steel, copper and African blackwood.
    Making a plumb bob-p1070341-large-.jpg Making a plumb bob-p1070363-large-.jpg Making a plumb bob-p1070364-large-.jpg Making a plumb bob-p1070365-large-.jpg Making a plumb bob-p1070564-large-.jpg Making a plumb bob-p1070563-large-.jpg
    Cheers
    Jimmy
  2. The Following 12 Users Say Thank You to Dimitris Polychronis For This Useful Post:
    anthonyget (Nov 6, 2020), Beserkleyboy (Nov 12, 2018), editor@glue-it.com (Jun 7, 2022), high-side (Feb 9, 2019), Jon (Nov 12, 2018), mklotz (Nov 12, 2018), mr mikey (May 2, 2024), PJs (Nov 18, 2018), Ralphxyz (May 2, 2024), ranald (Nov 13, 2018), Seedtick (Nov 12, 2018), Shanty (Nov 18, 2018)
    Supporting Member Beserkleyboy's Avatar
    Aug 2014
    Sunny South Coast NSW, Australia
    Beserkleyboy's Tools
    Very nice work! Makes my grandad's beat up old brass number look anemic! I'm sure it is a joy to use. Cheers
    Jim
    Phantom89's Avatar
    Dec 2015
    Dang you do good work. I don't have a tool box nice enough for that. It must live in a felt lined custom box. 👍
    Great material choice. This is one of the nicer plumb bobs we've seen, and we have 13 other ones listed: Homemade Tools: plumb bob - HomemadeTools.net
    One of the more awkward jobs to do accurately is marking the exact point over which a plumb bob hangs. Using the actual tip of the bob can damage it, especially if marking concrete, and is just, well, brutish.
    One approach I've seen to this problem is a bob shaped like a horizontal washer with four arrow points that point inward to the center of the annulus. After the bob comes to rest it's lowered carefully onto the stuff to be marked and a pencil mark made at the center of the four points. While it might work, it seems a bit gimmicky plus it wouldn't work well if the surface to be marked is angled.
    IMO, a much better solution would be a plumb bob with interchangeable points. Unscrew the normal, sharp steel point and fit a thin, ultra fine point Sharpie. Then simply lowering the stabilized bob onto the surface would leave a precise mark.
    Maybe I'm overthinking things - a machinist designing a push broom. Perhaps nobody needs to mark the sub-bob point that accurately.
    Nov 2018
    Athens-Greece
    Thank you Beserkleyboy! Although I haven't used it a lot - a couple times in the shop and 2-3 in home - it was a pleasure using it!
    Cheers
    Jimmy
    Nov 2018
    Athens-Greece
    Thank you very much Phantom89! Actually lives in a small velvet lined jewelry box.
    All the best
    Jimmy
  9. #8
    Nov 2018
    Athens-Greece
    Thank you Jon! I don't know if you saw the video, but I'm sure that you'll like this also
    Attachment 26326 Attachment 26327 Attachment 26328
    this was my contribution for Keith Fenner's WIYB 2015
    Cheers
    Jimmy
  10. #9
    Nov 2018
    Athens-Greece
    One approach I've seen to this problem is a bob shaped like a horizontal +washer with four arrow points that point inward to the center of the annulus. After the bob comes to rest it's lowered carefully onto the stuff to be marked and a pencil mark made at the center of the four points. While it might work, it seems a bit gimmicky plus it wouldn't work well if the surface to be marked is angled.
    You said it very wisely, Marv. It is an awkward job, especially when the marking height is greater than our body height. As for the interchangeable tip would be a good feature (commercially made ones have this feature).
    Cheers
    Jimmy
  11. #10
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    VERY PRETTY. I'd be scared to use it, as it may end up like my dad's lead one which I haven't used for around 10 years. I also inherited my grandfather's :it looks like it has a large nail as a tip, probably to prevent damage due to less than careful use.
  12. The Following User Says Thank You to ranald For This Useful Post:
