Working with steel is fun if you have the right tools.
Sheet metal roller bender is a machine that I don't have, so I decided to make it
I used a lot of scrap yard stuff so the cost was very low.
Thanks to the use of the motor and gearbox, I was able to resign from the crank, which made the work much faster and more pleasant.
With this tool, I can roll 2 mm thick and about 53 cm wide, which should meet my requirements.
