Quote Originally Posted by CanBeDone View Post
There are two items I am missing in your design: It is not adjustable, and it doesn't have a fence.
For a once-off job, being adjustable is, of course, not a issue. And if you are planning to bend several items, without a fence repeatability will be poor.
This is what I learned after building this
ID:	33533 following a suggestion found on this forum a few weeks ago, a three pin design very much like your own. Since I had to bend flat bar 6x32mm, instead of the pins I used pieces of 20mm plate, held in place by M10 bolts. The angle plate on the left is adjustable, and that is where my design failed: the three M10 bolts are not capable of holding the angle in place, and thus the bend is not as sharp and neat as I wanted it. Even though the high-tensile bolts have been tightened until the 20mm plate got (locally) deformed, the friction forces they do apply are not high enough, and slippage does occur - and thus the bend is no longer sharp.
There is a solution, however, as exampled by tuomas Vise bending attachment: Instead of three pins use two vises, joined by a hinge. When closed loosely, these vises ought to give just the control over pin spacing that I need to give me the sharp bend that I want.
For the vises, I will follow closely this design, used here on a rotating table: Click image for larger version.
ID:	33534. Essentially, a M12 grubscrew has been grooved such that a 3mm roll pin connects it to the moving jaw, without blocking its ability to rotate freely.
My fence is just an afterthought; it works just as well as any more fancy machining could have given me.
CanBeDone,
Thanks for sharing your experience! So far, I have been just playing around with the tool so had not considered problems related to repeatability. I have figured out the correct place to set the wire so the bend occurs where I want it so that is related to repeatability. If I understand your setup correctly involving two vises, I think it poses a problem for me. Say I want to bend this 7 gage wire every 1/4". I can see how the first bend would work with two vises but can't figure out how to do subsequent bends. Can you say more about how the two vises work?
Thanks,
Rick
