Results 1 to 10 of 15
Thread: micro-controller based dividing head
    Supporting Member EclecticNeophyte's Avatar
    Apr 2013
    TriCities, WA.
    EclecticNeophyte's Tools
    Here's my latest homemade tool...just finished the wiring and testing today. It's a dividing head, using a NEMA 23 stepper motor, coupled to a ER20 collet chuck via timing pulleys and belt. The ER20 is mounted in a couple of sealed ball bearings, that are in turn pressed into a 3" x 3" x 5" block of aluminum. The stepper is capable of 400 steps (0.9 deg/step), with a 4:1 ratio on the timing pulleys. This results in a maximum resolution of 1600 divisions...
ID:	2613Click image for larger version.
ID:	2614Click image for larger version.
    I plan to use this dividing head, to cut spur gears and timing pulleys for other projects.
    -EN
  2. The Following 17 Users Say Thank You to EclecticNeophyte For This Useful Post:
    Barend (Sep 28, 2019), bgerens (Feb 6, 2018), Christophe Mineau (Jan 1, 2015), emu roo (Jul 19, 2024), Harris Creek Central (Dec 31, 2014), kbalch (Dec 30, 2014), Miloslav (Sep 25, 2019), mwmkravchenko (Nov 16, 2022), Neil Jensen (Jun 18, 2016), Paul Jones (Dec 30, 2014), Ralphxyz (May 24, 2024), tonyfoale (Mar 27, 2017), Tonyg (Jul 19, 2024), tooly (Sep 7, 2019), wimton (Nov 19, 2022), winmac (Nov 16, 2022), Workshopshed (Aug 21, 2016)
