Results 1 to 9 of 9
Thread: Mini plate compactor for sandstone slabs
  1. #6
    olefella's Avatar
    olefella's Tools
    Quote Originally Posted by Pa1963 View Post
    You shouldn't have to tamp the slabs if you've properly compacted the base. It's the whole point of having laid base-to provide a solid, stable surface to lay your paving on.
    The slabs vary in thickness from 28-35 mm, and, while the undersurface is saw cut some have flakes broken off so it’s not always even. The base is compacted FCR, and I have brushed off all largish chips so it’s pretty flat and stable. There’s a layer of sharp sand under the slabs allowing them to settle so their top surface is even. I started off tamping them with a rubber mallet but they need a bit more hence the vibrater. I’ve laid smooth concrete slabs before, but not sandstone, so maybe I’ve got something wrong, but this seems to be going ok now.
  2. The Following 2 Users Say Thank You to olefella For This Useful Post:
    emu roo (Jul 28, 2025), PJs (Jul 28, 2025)
