Results 1 to 6 of 6
Thread: Mobile gas powered air compressor
  1. #3
    Aug 2018
    Thanks WarsztatOdZera. Good build! I did not see a wire going to the drive clutch. Did you use a clutch that engages at a certain RPM of the engine? Is the engage speed adjustable at the clutch or is it simply controlled by the spring tension?
  2. The Following User Says Thank You to greyhoundollie For This Useful Post:
    emu roo (Dec 4, 2025)
