Results 1 to 9 of 9
Thread: Module Gear Cutter Arbor
    Dec 2013
    Florida
    rossbotics's Tools
    I made this arbor for holding a #3 - 1.5 Module gear cutter. Seams as someone on 2nd shift at work wanted to play with the lathe and jammed the carriage of the lathe all the way against the headstock and stripped the power feed gear.
    It's a chineez lathe so getting replacement parts was just totally out of the question.
    So my boss asked if I could make one at my shop. I told him it wasn't a problem. I told him what cutter to order and the bronze I needed and I would make an arbor for the cutter. I also had him order me a 17 tooth #20 chain sprocket for indexing purposes.
    The indexing fixture I used is one I made along time ago, way before I new about homemade tools. It's constructed from a piece of 1.500 X 2.500 X 3.500 aluminum stock with an indexing pin mounted to the side of the block, It accepts a piece of 3/4" round stock as the arbor ,The 3/4" arbor is machined on both ends one end to accept a gear blank and the other to accept a gear or sprocket for indexing, It's a very simple devise but works beautifull.
    Below are some photos
    As always thanks for looking
    And happy Machining
    Doug
    Click here to purchase a set of these plans http://www.homemadetools.net/forum/m...or-plans-46305
    End View
    How I indexed the teeth
    Fixture tilted at a 4 degree angle to match the lead of worm gear
    Finished Product
    Comments are always welcome
    Doug
  2. The Following 8 Users Say Thank You to rossbotics For This Useful Post:
    C-Bag (Aug 27, 2016), emu roo (Sep 11, 2025), Floradawg (May 4, 2022), kbalch (Aug 7, 2015), PJs (Aug 7, 2015), rdarrylb (May 4, 2022), scoopydo (Aug 29, 2016), Vyacheslav.Nevolya (Aug 27, 2016)
