Results 1 to 9 of 9
Thread: Module Gear Cutter Arbor
  1. #5
    Dec 2013
    Florida
    rossbotics's Tools
    Thanks everyone for the compliment, as to your question PJs about the arbor ? It is straight piece of CRS , it is turned down to 5/8" on the end that holds the gear blank, and turned down to 5/8" on the other that holds the sprocket, there is no key or any other driving method to drive the gear cutter it's secured by the thick washer and the 5/16" socket head cap screw, the rotation of the cutter will actually have a tendency to tighten itself, I didn't see a need for a key or anything, depth of cut was only .133" and it was bronze, nota problem
    Thank You
    Doug
    Comments are always welcome
    Doug
  2. The Following 3 Users Say Thank You to rossbotics For This Useful Post:
    emu roo (Sep 11, 2025), Paul Jones (Aug 26, 2016), PJs (Aug 7, 2015)
