Hi Milan3181
To answer your question we need to know more information.
Could you post a picture of your saw? Could you also give us some dimension (saw diameter and thickness), the kind of wood (oak, firtree, plywood,...) and the maximum thickness and height you will cut.
To add some comments I can compare to my own needs as I have both a blade saw (diameter 315 mm, thickness 3 mm) and a band saw (440 mm wheels) with both 3phases 3kW motor. with which I can cut hard wood (70 mm thickness with the blade and 240 mm with the band saw).
The blade is noisier than the band saw, but both are noisy (and the motor is silent) because of the minimum speed to properly cut wood (50 m/s).
In fact you can compare the blade with a fire siren : each tooth is a small blade which cut an air stream ...
So give us some more details and we can help you.
Regards.
Bernard 1500 km SSW of you.
