Results 1 to 5 of 5
Thread: Mower blade balancer
    Jul 2018
    Flora, MS
    Floradawg's Tools
    I used to balance my mower blades by laying a twist drill or small piece of round stock on the bench and lay the blade on it like a seesaw. Today I made this one.
    The only dimension that is important is the diameter of the column on the part that the blade slides down on. Most blades have a toothed hole. I found the diameter by turning a piece of delrin in my other lathe taking off small amounts until it fit the blade. If you only have one lathe, do this first. I also tapered the lower step so even if the blade hole was a little bigger, it should still sit in the center. I drilled a 1/2" hole and tried it out. The top pointed end of the hole didn't really locate the pointed end of the screw to my liking. So, I flattened out the end of the hole and used a center drill to make a dimple. That worked well. I didn't include any dimensions because for the most part, they aren't important. I pointed the end of the screw by chucking up the lower assembled part and used a file while it turned in the lathe. It worked well.
ID:	49488   Click image for larger version.
ID:	49489   Click image for larger version.
ID:	49490   Click image for larger version.
ID:	49491   Click image for larger version.
  2. The Following 5 Users Say Thank You to Floradawg For This Useful Post:
    emu roo (Jul 23, 2025), hemmjo (Jul 27, 2025), Karl_H (Jul 23, 2025), PJs (Jul 23, 2025), Tule (Jul 23, 2025)
