Thanks for the input so far.
I checked out the heat pump manifesto, very interesting, but no real controller.
I hesitate to gamble on a those from eBay especially since one seller, located in HongKong is selling an item from Ohio, which is where I am located. The other also in Ohio is in Spanish. Probably 2 sites selling the same item. The skeptic in me sees a scam of some sort so not worth the gamble for a used controller.
I have compared the two controllers and swapped them between units. The problem is for sure with one controller. The issue is the LEDs that display status, i.e, heat, cool, auto, off, and fault, do not work. I can tell the mode, by watching the temperature set-points change as I switch between modes. So I know when it is in Heat, Cool, Auto or OFF. It is functioning for now but if there is a fault, I would not see that, the unit would just stop running.
As suggested, I have examined the board for signs of failure, having repaired several digital automobile dash components, a climate control module, 2 different speedometers and a tachometer, by simply reheating all of the solder at the circuit board connections. I just hesitate to mess with this unit since it is working. I do not see any of the typical signs of a failed component on the board. Since all of the LEDs quite working at the same time, it could very well be just a failed solder joint. If it had failed completely I would try resoldering everything. I may the resolder in the spring when I have time to do something else if I ruin it completely.
I have been wondering about trying a PLC, perhaps using one to control and stage both units. I will have to look into that if nothing else comes to light.
John
