Results 1 to 7 of 7
Thread: Need help - press drill spring
  1. #4
    Nov 2015
    Italy
    rendoman's Tools
    Thank you all for the advices!
    It's nice this C shape ring,it seems better than the wire!
    I just fixed the spring! As olderan said, I had to cut the spring and re forming the stop loop with oxy torch. I cut more or less 60cm, in order to put the spring inside the bobbin. With surprise I noticed that the energy stored was high (when I cut the wire), but to be honest it was perfectly manageable with leather gloves. I added a little pre-loading of 2 turns. The spindle axis returns fluid, the descent is light. I hope this spring will last !
ID:	23965 Click image for larger version.
  2. The Following 6 Users Say Thank You to rendoman For This Useful Post:
    Andyt (May 30, 2018), olderdan (May 30, 2018), Paul Jones (May 30, 2018), PJs (May 31, 2018), thehomeengineer (May 30, 2018), Toolmaker51 (May 30, 2018)
