Results 1 to 10 of 10
Thread: No Vacuum Water Bath Dust Collector
    TigerCreek's Avatar
    Feb 2019
    TigerCreek's Tools
    I got tired of the vacuum noise and came up with a smaller, quieter system to remove dust from my blast cabinet.
    Inexpensive and works very well.
  2. The Following 9 Users Say Thank You to TigerCreek For This Useful Post:
    DIYer (Jun 23, 2020), dubbby (Jun 23, 2020), emu roo (Jun 13, 2024), high-side (Jul 3, 2020), Jon (Jun 25, 2020), odd one (Jun 28, 2020), Scotsman Hosie (Jun 25, 2020), Sleykin (Jun 29, 2020), Toolmaker51 (Jun 28, 2020)
    Thanks TigerCreek! We've added your Water Bath Dust Collector to our Dust Collectors category,
    as well as to your builder page: TigerCreek's Homemade Tools. Your receipt:
    emu roo (Apr 16, 2026)
    Dec 2017
    Quote Originally Posted by TigerCreek View Post
    Very nice idea, thanks.
  6. The Following User Says Thank You to Moldyjim For This Useful Post:
    TigerCreek's Avatar
    Feb 2019
    TigerCreek's Tools
    Thanks. It’s working great as an alternative to my previous vacuum system.
  8. The Following User Says Thank You to TigerCreek For This Useful Post:
    Apr 2012
    NorCal
    Saltfever's Tools
    Thank you. Very creative and great idea. I would have liked to see you actually blasting a part which in itself creates copious debris. That visual would have been a great validation.
  10. The Following User Says Thank You to Saltfever For This Useful Post:
  11. #6
    TigerCreek's Avatar
    Feb 2019
    TigerCreek's Tools
    You are correct. My original use of this setup, minus the bath, was used in another cabinet that is used exclusively for dirty blasting. I built on that success to add the water bath and scale down my other cabinet.
  12. The Following User Says Thank You to TigerCreek For This Useful Post:
  13. #7
    Dec 2018
    A pipe clamp could have helped fit the PVC to the fan. I am sure the fan has a power rating that dictates the amperage requirements of the ac adaptor. The filter material probably adds surface area. Does any particulate come out the top of the modified collection system? If so a collection bag of some type might be necessary to collect that rather than allow it to enter your work space. Overall really great compact idea for a one tool application.
  14. The Following User Says Thank You to Nick79 For This Useful Post:
  15. #8
    TigerCreek's Avatar
    Feb 2019
    TigerCreek's Tools
    Quote Originally Posted by Nick79 View Post
    I mention all of these things in the video.
    I found that the "trick" to controlling the efficiency of the unit is the height of the water in the bucket.
    A full day of blasting Saturday and I had only the slightest bit of dust on the blades of the fan.
    Adding a bag or top collector that would not impede the flow would certainly be an option if you found it necessary.
  16. The Following User Says Thank You to TigerCreek For This Useful Post:
  17. #9
    Supporting Member Sleykin's Avatar
    Oct 2017
    Medford, Oregon USA
    Sleykin's Tools
    If the small amount of dust that escapes is objectionable you could always exhaust it outside.
  18. The Following User Says Thank You to Sleykin For This Useful Post:
  19. #10
    TigerCreek's Avatar
    Feb 2019
    TigerCreek's Tools
    That’s how this process all started.
    I have another cabinet that I do the really nasty blasting in and visibility was terrible. I hooked up one of these fans and exhausted the cabinet outside. Worked great. Then I began working on what I have here for inside blasting and to replace the vacuum.
  20. The Following 2 Users Say Thank You to TigerCreek For This Useful Post:
    emu roo (Apr 16, 2026), Sleykin (Jun 30, 2020)
