Results 1 to 5 of 5
Thread: Nut and bolt extractor tool - GIF
    May 2024
    Nut and bolt extractor tool.
    Combination lock from bolts - video
    Creating a spring with a bolt - GIF
    Freezing off a stuck bolt - GIF
    Giant bolt head press - GIF
    emu roo (Jan 2, 2026), Floradawg (Jan 2, 2026), nova_robotics (Jan 2, 2026)
    hemmjo's Tools
    That "broken off" piece was not STUCK in the T
  4. The Following User Says Thank You to hemmjo For This Useful Post:
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    Yeah, there's no way that a soft bolt could grip the pipe that well. It would slip more readily than it would tap into place.
    Maybe it would work (a little) if you put lock washers with external teeth between the bolt and pipe. They're hardened steel and would dig into both the bolt and the pipe.
    Neil
    If you look really close at the very beginning of the vid the dutchman appears to wiggle when the guy's finger touches it. Could probably had stuck his thumb in it and rotated it out easy enough.
    Apr 2016
    Buffalo, NY
    I have removed broken pipe ends by using just a hammer and chisel. I put the end edge of the chisel between the pipe and nipple and swing away. Works every time. I also sometimes spray the pipe with PBS spray and or heat up the fitting with propane. These help too.
