Results 1 to 7 of 7
Thread: Occasional depth gauge for tail stock
    olderdan's Tools
    I felt the need for an accurate depth control for some counter bores so came up with an occasional digital solution namely a cheap tire tread depth gauge with 1 inch travel. My SB lathe tailstock has a round topped casting which is not ideal for this, I am reluctant to machine a flat on this old lathe so another way had to be found. I made a base from epoxy metal putty to fit the top of the casting and epoxied 5 neodymium magnets in the base which hold very well. These gauges are not spring loaded so a bracket and spring were added (I keep every spring I come across of any size) that just left a bracket to make for the barrel which apart from the bore was hand fashioned, good old hacksaw and file was much quicker than machining the whole thing. It only takes a couple of minutes to fit when needed and tooling still ejects with the bracket in place. I should add that the idea is not mine as many variants have been posted on HMT, this is just my take on the application.
ID:	36098Click image for larger version.
ID:	36099Click image for larger version.
  2. The Following 10 Users Say Thank You to olderdan For This Useful Post:
    baja (Aug 10, 2020), bill46 (Aug 10, 2020), Carnel (Aug 4, 2020), CookieCrunch (Aug 4, 2020), goonergord (Jun 20, 2022), Jon (Aug 6, 2020), LMMasterMariner (Aug 3, 2020), Okapi (Aug 4, 2020), Paul Jones (Aug 4, 2020), SculptyWorks (Aug 4, 2020)
