If your engines oil pump drive is shared with the distributor drive an old distributor shaft can be used to prime the oiling system before starting a newly rebuilt engine, by simply attaching the shaft to an electric drill.
kbalch (Feb 10, 2014)
Thanks pursang! I've added your Oil Pump Primer to our Engine category, as well as to your builder page: pursang's Homemade Tools. Your receipt:
pursang (Feb 10, 2014)
Definitely something I should've mentioned in the post, the direction should follow the engines firing order,
installing a mechanical oil guage with an opaque oil line would also allow you to observe the flow of oil and let you know the kind of oil pressure your drill will produce.
Your welcome Norm
kbalch (Feb 21, 2014)
