Thread: Parallel ring mandrel
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    This again may not be of interest to all.
    I have been working on the Trunk Guides for my 3" Foden steam wagon which is a reasonably complex casting to machine and hold. So to aid this process, I used a parallel ring mandrel which is perfect for this application as an expanding mandrel wouldn't work as the casting has a blind bore.
    The first step as with most castings is to establish that every thing is going to fit so marking out and creating some datums.
    In the case of the trunk guides I machined a datum diameter which also enabled the casting to be chucked in the 3 jaw chuck so the 1" diameter bore could be machined to size.
    A piece of steel was then machined to an accurate slide fit to the 1" bores and a 1 degree taper, is then machined at the end to lock the casting in place.
    The casting is lightly taped on to the mandrel and the machining of the casting can then be completed.
    The photos and video will hopefully aid this explanation.
Name:	boring diameter.jpg
ID:	45226Click image for larger version.
ID:	45235Boring casting with the aid of a fixed steady for extra support
Name:	compound slide 1 degree.jpg
ID:	45227Compound slide set to 1 degree
Name:	taper turning.jpg
ID:	45236Click image for larger version.
Name:	1 degree taper.jpg
ID:	45228Taper at the end of the 1" diameter
Name:	finished ready.jpg
ID:	45229Ready to accept casting
Name:	casting on mandrel.jpg
ID:	45230Casting on mandrel
ID:	45231Click image for larger version.
ID:	45232Facing end of casting
ID:	45233Measuring overall length
Name:	standard mandrel.jpg
ID:	45239Click image for larger version.
Name:	finished turned.jpg
ID:	45238Click image for larger version.
Name:	support from tailstock.jpg
    Once the casting was faced to length, the mandrel taper was machined off and a stud fitted to complete turning
    I hope this was of interest and thank you for viewing
    The Home Engineer
  2. The Following 2 Users Say Thank You to thehomeengineer For This Useful Post:
    Philip Davies (Apr 4, 2023), piper184 (Apr 4, 2023)
