Results 1 to 6 of 6
Thread: Phalanx CIWS shooting down a drone - GIF
    Phalanx close-in weapon system (CIWS) shooting down a drone.
    drone takedown tools: beam guns and eagles
    Gatling gun made from SKSs - GIF and video
    Bomarc surface-to-air missile intercept - GIF
    Patriot PAC-3 TBM intercept - GIF
  2. The Following 5 Users Say Thank You to Altair For This Useful Post:
    baja (Jan 9, 2020), nova_robotics (Nov 10, 2022), Rangi (Jan 13, 2020), Seedtick (Jan 8, 2020), tuchie (Jun 23, 2024)
    If only the fleet had had a few score of those at Okinawa.
    hemmjo's Tools
    At that rate of fire, that thing sure does burn through some ammo. I wonder if that whole big chamber above the "business" end holds ammo? Or if that is the electronics and control systems.
    Jul 2016
    Look at the drum under the barrel, lower "window" shows belted ammo buzzing past. The dome on top is likely fire control radar of some sort.
    Supporting Member Big Sexy's Avatar
    Bullets are still way cheaper than any type of missiles.
    Yes, the dome houses the radar and fire control system.
    I've been told that it works so well because the radar tracks not only the target but also the bullets in flight to said target. This makes fire control a lot easier and more accurate. All the system has to do is maneuver to bring the two radar images into coincidence. That's much easier than trying to predict the flight of the target and generate the required "lead" for firing a projectile sitting in the chamber.
