Very good idea. I believe you could solve the .003 OOS issue easily.
The process of manufacturing washers [punching ID, stamping OD] does not insure flat parts. Next, surface of cast piston is likely not dead perpendicular to skirt, especially in 3 locations. Finally, small relative area of cap screw could 'dent' each washer into different cup shapes.
Use 3 smaller, narrower [there fore stiffer] contacts held the same way. 3/16" keystock, dowel pins, etc. 3 points of contact is always stable, yet no assurance each is on same plane.
Just like surveyor's tripod, adjustable legs AND leveling jackscrews.
As long as you can crouch and lean, you can still ride.
