Results 1 to 8 of 8
Thread: Pivot hinge with fine adjustment for vertical on the pin.
  1. #4
    Oct 2017
    Close here is a photo, plummer blocks are cast iron units into which a bearing is inserted. The bearing can move a bit to self align in the block.Click image for larger version.
ID:	42207Click image for larger version.
    You may notice on the square tube column rising from the bench or even the first 'knuckle', a bolt head on one side and at 90 degrees another bolt head higher up the sq tube.
    They are the adjustments. A single bolt right through at those 2 positions.
    John Daley
    Bendigo, Australia
  2. The Following 2 Users Say Thank You to jdaley For This Useful Post:
    Sleykin (Jun 8, 2022), Toolmaker51 (Mar 18, 2022)
