Results 11 to 17 of 17
Thread: Polishing wood with Boiled linseed oil
    Nov 2015
    Italy
    rendoman's Tools
    Hi!
    I just finished to polish my new speakers, since I havn't found a convincing guide I decided to post my experience.
    The wood is Afromosia, from Paraguay, glued with PVA glue (Vinavil). First prepare the surface wih sand paper till 320 grit (all the steps from 80 grit), then apply a mix of 50% boiled linseed oil - turpentine. The first two hands plenty, I found pretty useful a jeans small rag, it doesn't shed hairs and helps polishing. The following coats with less oil and more rub, 30 min after each hand it's good to clean the surfaces from residue. With less oil applied the drying time is shorter. After the VII coat (half day rest) a light clean with jeans rag with turp.
    To reach a nice high surface apply a mix of Carnauba and Beeswax by hand and remove with wool cloth. I found pretty convenient to use the polisher tool, not very traditional but effective.
    I found this method accurate and good for the result. I tried in the past another method with no satisfaction: it used pure oil in the last coats, a messy work.
    Details of the sanding and first fresh coat.
ID:	39312 Click image for larger version.
ID:	39313 Click image for larger version.
    Intermediate steps.
ID:	39315 Click image for larger version.
ID:	39316 Click image for larger version.
    Final polishing with power tool.
ID:	39318 Click image for larger version.
ID:	39319 Click image for larger version.
  2. The Following 6 Users Say Thank You to rendoman For This Useful Post:
    baja (Apr 29, 2021), blkadder (Mar 25, 2024), carloski (Apr 30, 2021), nova_robotics (Apr 28, 2021), Paul Jones (Apr 29, 2021), Toolmaker51 (Apr 28, 2021)
