Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: poor man's square broach
    A new member was asking how to drill square holes so I thought I would share a process that I have used successfully in the past
    for instance to make a 5/16" square hole in soft material or even in mild steel as long as it is not too thick I have taken a 7/16" NC starting tap and ground it square. the teeth will broach out the material to make a square hole. Care must be taken when doing it like this because the 60° cut angle is wrong for this application
    press the modified tap through the holes
    here is a drawing of how the tap would look
    Ideally you would use a 5/16 sq piece of tool steel ground to the shape of a broach
    like this
  2. The Following 28 Users Say Thank You to Frank S For This Useful Post:
    Andyt (Jan 3, 2019), baja (Oct 3, 2020), Captainleeward (Dec 22, 2017), Cascao (Dec 22, 2017), EnginePaul (Dec 24, 2017), greyhoundollie (Jan 3, 2019), high-side (Jan 3, 2019), j.bickley (Dec 19, 2017), Jon (Mar 13, 2016), kbalch (Mar 13, 2016), kngtek (Dec 22, 2017), lazarus (Jul 11, 2016), Moby Duck (Dec 20, 2017), mwmkravchenko (May 11, 2018), n9dug (Oct 3, 2020), Okapi (Aug 14, 2016), olderdan (Dec 22, 2017), Paul Jones (May 16, 2016), Philip Davies (Oct 3, 2020), PJs (Mar 15, 2016), Scotty12 (Oct 2, 2020), Sleykin (Dec 20, 2017), Stevohdee (Sep 12, 2018), thehomeengineer (Jan 5, 2018), Toolmaker51 (May 18, 2016), tooly (May 11, 2018), trigger (Oct 2, 2020), ttmrj (May 28, 2022)
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    I like that idea. will now have to hank on to all non sharp taps for this purpose.
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
    they are no replacement for a proper broach but in a pinch and with care you can make quite a few hole turn square before the teeth break off
    Mar 2013
    Switzerland
    Okapi's Tools
    A good and inexpensive idea, we have all old threading tools broken or used.
    California, central coast
    C-Bag's Tools
    Quote Originally Posted by Okapi View Post
    +1
    I was just thinking that the other day as I was getting ready to toss a chipped 3/8" tap. I love thinking I'm not really hoarding, I'm just waiting to find the right re purpose
  7. The Following 3 Users Say Thank You to C-Bag For This Useful Post:
    EnginePaul (Dec 24, 2017), greyhoundollie (Jan 3, 2019), Paul Jones (Aug 15, 2016)
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I am with you on keeping the broken taps, drills, etc. I keep anything broken or worn out and made from HSS in a box waiting for the right re-purposed tool.
    Mar 2013
    Switzerland
    Okapi's Tools
    All "old " mecanicians have a big tin bean can where we put all the "can be useful sometimes later"…
    And when you need a small piece of very good steel to make a new centering pin for example, what better than a broken tap.
  10. The Following User Says Thank You to Okapi For This Useful Post:
    Paul Jones (Aug 16, 2016)
    May 2013
    Very slick, Frank! Thanks!
    ---Joe
    It'd not hoarding. It's the fuel of creativity waiting for sparks from your mind.
    It works like this: A pile of treasure fills all available flat spaces. In recognition of this problem you use some of the stuff to create storage in the air volume above the other stuff. Cardboard, yellow carpenter glue, cutting tools, assorted spring clamps and a can of left over paint are needed. Now you have new flat space to fill.
    Repeat the cycle; but take time to mark things for ID and make dividers for the little containers. Show someone your accomplishment and tell them it's not hoarding, it's creativity
    2nd repeat cycle. Attach stack of storage containers to wall to keep gravity at bay.
    Go into Michaels or Hobby Lobby and come out with nothing but some new storage boxes that were on sale.
    You are beginning to feel artistic. Buy another can of mismatched paint; but a different color.
    3rd cycle. There is no longer any space on the workbench except where the vise is mounted. You find a scrap piece of plywood and attach a stringer board to the back that will allow this new little mini-workbench in the jaws of the vise. Voila!! New flat space in thin air!
    People you know are beginning to notice ..............
  13. The Following User Says Thank You to Ed Weldon For This Useful Post:
    b andritsch (Jan 31, 2023)
  14. #10
    Ralphxyz's Tools
    Nice, great idea.
    Ralph
