3 Attachment(s)
Power feed for my mill.
I built this power feed for my mill a while ago and thought I would post it. The motor was purchased at Princess Auto in their bargain bin so I don't have much info on it. The speed and direction controller I got off of ebay and the power supply is a garage sall item. When I first built it I tried it out and then left it sit, it was to much trouble to unhook it when manually doing some work. I found a dog clutch article by John Krueger on-line and recently made one following his plans and changing what I had to to make it work on my Craftex mill. Now I use the power feed for most things and the amazing part is how much better finish you get with a power feed especially when fly cutting. The speed range is very good, it will go slow enough to move only .25 of an inch in 2 minutes and will move 5-6" a minute on faster setting. The clutch is very easy to use so if I want to move very fast I disconnect the feed and do it manually. I will attach some photos and the PDF file of John's clutch. The pdj is to large to upload but this is the link to it. littlemachineshop.com/projects/Drawings/ClutchConnnector.pdf
Thanks blackangus! I've added your Mill Power Feed to our Electrical category, as well as to your builder page: blackangus' Homemade Tools. Your receipt:
<div id="blocks">
<div class="block b1 pngfix">
<div class="bimg">
<div>
<a href="/mill-power-feed-7"><img src="/uploads/113046/mill-power-feed-7.jpeg" alt="Mill Power Feed" /></a> </div>
</div>
<div class="title">
<a href="/mill-power-feed-7">Mill Power Feed</a> <span> by <a href="/builder/blackangus">blackangus</a></span> </div>
<div class="tags">
tags:
<a href="/tag/power-supply">power supply</a>, <a href="/tag/mill">mill</a>, <a href="/tag/clutch">clutch</a>, <a href="/tag/electrical">electrical</a>, <a href="/tag/motor">motor</a>, <a href="/tag/power-feed">power feed</a>, <a href="/tag/controller">controller</a> </div>
</div>
</div>
</div>
Nice build, blackangus! As you noted, I like the speed range of your power feed.
Nice I'm going to put a power feed on my mill too. I've deen looking at the ones people build . I like the idea of a clutch will look into that. I want to put one on the head too , my mill has the round column , think I'm going to try and make a locating bar to zero it out up and down.
