Power feeding a shredder knob
Hi,
My Stihl shredder is a great gardenning tool, it's powerfull and reliable, but it is inevitable that from time to time, it gets clogged...
https://www.labellenote.fr/file/home...ocket_0001.jpg
To fix that, you need to unscrew both of the black knobs on the front (maybe 20 revolutions each), clean the blades up, re-screw both of the knobs, start again, and sometimes, it can happen more often than desirable, you get quickly tired of screwing, unscrewing with both hands ...
I had the idea to speed up the process, using a power screwdriver. So I needed a big socket that could fit on the knob.
In order to check how I could do that I initially 3D modelized the knob, I was thinking doing something with my CNC out of wood.
https://www.labellenote.fr/file/home...ocket_0002.png
But I realized I had this big brass fitting sitting on a shelf, and it could do just right with "little" work.
So I decided to go the conventional way, using my mill and my lathe. (I like it !)
Here are some pictures of the process and eventually the final product I came up with.
https://www.labellenote.fr/file/home...ocket_0003.jpg
https://www.labellenote.fr/file/home...ocket_0004.jpg
https://www.labellenote.fr/file/home...ocket_0005.jpg
https://www.labellenote.fr/file/home...ocket_0006.jpg
https://www.labellenote.fr/file/home...ocket_0007.jpg
https://www.labellenote.fr/file/home...ocket_0008.jpg
https://www.labellenote.fr/file/home...ocket_0009.jpg
https://www.labellenote.fr/file/home...ocket_0010.jpg
https://www.labellenote.fr/file/home...ocket_0011.jpg
https://www.labellenote.fr/file/home...ocket_0012.jpg
Thanks for reading !
