Results 1 to 9 of 9
Thread: Press brake for hydraulic press
    Jyväskylä Finland
    Tuomas's Tools
    Made a simple brake to my press.
    Info about mounting the jack: http://www.homemadetools.net/forum/m...255#post109941
    Info about the actual press: http://www.homemadetools.net/forum/h...615#post104791
    Allows to bend max 310mm wide 5mm sheets with 15mm radius.
    Material is 10mm thick steel plate, valve springs from a truck and machine steel (SBQ) for the blade guides.
    Video about the use: https://www.instagram.com/p/BsQqEcbg-wS/
  2. The Following 11 Users Say Thank You to Tuomas For This Useful Post:
    Andyt (Jan 8, 2019), baja (Mar 4, 2021), emu roo (Jun 4, 2025), Janvosburg (Jan 8, 2019), Jon (Jan 7, 2019), LMMasterMariner (Jan 16, 2019), nova_robotics (Mar 3, 2021), PJs (Jan 9, 2019), Rangi (Feb 14, 2026), sossol (Jan 10, 2019), that_other_guy (Jan 8, 2019)
    Aug 2016
    wizard69's Tools
    very nice! looks like your next project should be a bigger press.
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by wizard69 View Post
    Thanks. I think that will do fine for a while.
    But someday..
  5. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Jan 9, 2019)
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Nice little Press Brake Tuomas! Great addition to your shop! Did you put bushings in the upper post housing?
    PJ
    Mark Twain
    Jyväskylä Finland
    Tuomas's Tools
    PJ
    Thanks buddy. Nope. Jack and the post / blade are are at the same line, so blade stays straight enough without pushings.
    Housings are made from pre-machined tube here its called " ainesputki" its sold in hardware stores. I found suitable axles from the eye bolt. So i got good enough fitting without lathe.
    Cost for the material was about 25$.
  8. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Jan 10, 2019)
    Thanks Tuomas! We've added your Press Brake Attachment to our Brakes and Presses category,
  10. #7
    Supporting Member JoeVanGeaux's Avatar
    Jun 2018
    Magnolia, TX
    I like this! Good work!
    I don't have any of this equipment on hand but I have an upcoming project in mind that would need a similar setup; however, I have been researching how to invert one of the air-over-hydraulic style jacks (maybe even one of those so-called "long jacks") to be setup like yours and would be powered by an air compressor - so I can get quicker cycling times.
    I've seen stuff on the internet that come painfully close but none like yours and especially none inverted that also has air-over-hydraulic functionality. Any ideas or pointers that would not involve a complete re-make of the jack? (Note to Admins: Apologies if this is not the correct place to ask this, please advise if not.)
    Regards
  11. #8
    Jyväskylä Finland
    Tuomas's Tools
    Supposed to make a video from this long time ago.
    But i lost most of the clips about the making.
    So, i decided to make little different video this time.
    Subtitles are English ( kind of language that i tend to use )
  12. The Following User Says Thank You to Tuomas For This Useful Post:
    PJs (Feb 13, 2019)
  13. #9
    Aug 2020
    Nice little break.
