Results 1 to 10 of 11
Thread: Pressure cooker explosions - GIFs
    Pressure cooker explosions.
    Industrial pressure cooker - GIF
    Tanker truck blows pressure relief valve - GIF
    Oxy-acetylene gas bottle crash explosion - video
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    carloski (Jul 9, 2022), durrelltn (Jul 10, 2022), EnginePaul (Jul 13, 2022), nova_robotics (Jul 9, 2022)
    I'm glad my pressure cooker / canner has a lock that makes it quite impossible to open the lid, built into the pressure release valve is some kind of secondary latch that will not under any circumstances release with the slightest amount of pressure inside.
    mwmkravchenko (Jul 10, 2022)
    Oct 2016
    old kodger's Tools
    Yes Frank, My canner has a secondary lock as well, but it's between my ears.
  6. The Following 6 Users Say Thank You to old kodger For This Useful Post:
    Altair (Jul 13, 2022), EnginePaul (Jul 13, 2022), Fluffle-Valve (Jul 10, 2022), Frank S (Jul 9, 2022), jackhoying (Jul 10, 2022), mwmkravchenko (Jul 10, 2022)
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    Most pressure cookers have a locking mechanism you can bypass, if you work at it hard enough. I have both older and modern ones, and a determined person could probably open any of them while under at least some pressure. Never underestimate the power of human stupidity and determination.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
  8. The Following 2 Users Say Thank You to schuylergrace For This Useful Post:
    mwmkravchenko (Jul 10, 2022), NeiljohnUK (Jul 11, 2022)
    Oct 2012
    Lafayette, Indiana
    sossol's Tools
    Neither of these are explosions - they are idiots opening them before the pressure returned to normal atmo. The first one had to really work at it.
    Neil
  10. The Following 2 Users Say Thank You to sossol For This Useful Post:
  11. #6
    Jul 2016
    My pressure cooker is the original design with an internal lid which is impossible to remove un till zero pressure, do not know why this design was never changed.
  12. #7
    Perth Ontario Canada
    People are opening these pressure cookers without releasing the pressure? Or the release is blocked because they overfill the pot? There have been safety locks and safety valves for nearly 50 years. But if you don't use them, well this happens. That can be some terrible burns. Especially the second lady and the first older man.
  13. #8
    neilbourjaily's Tools
    That second one had to hurt with all that scalding water on the woman's legs not to mention a chin side landing.
  14. #9
    Sep 2015
    Ontario Calif USA
    The snowflakes of today should be thankful for the microwave oven.
    Jim
  15. The Following User Says Thank You to jimfols For This Useful Post:
  16. #10
    Oct 2016
    old kodger's Tools
    Now comes the time for an incriminating admission, I have actually had a pressure cooker explode, but it did not release it's lid. The explosion occurred within the pot because it had chicken bones,fat, etc which I was boiling down for stock. It was on the BBQ outside, and I forgot about it, it got so hot that the fat turned into vapour. I can only presume that some oxygen must have still been inside because it did an internal burp and destroyed the lid and seriously bent the lugs it locks down on. When I remembered it, it was still happily cooking away, totally black and bent to the dunny, AND OUTSIDE.
  17. The Following User Says Thank You to old kodger For This Useful Post:
    mwmkravchenko (Jul 11, 2022)
