Results 1 to 10 of 12
Thread: Quick locking tilting angle grinder handle.
    Jyväskylä Finland
    Tuomas's Tools
    Hi
    This is very simple, but usefull "tool" for your angle grinder.
    It allows to adjust the angle of the handle of it.
    Takes less space when stored.. gives more ergonomical hold from the grinder in different task..
    when cutting, grinding, in different positions or workpiece down or high.
    Edit, plans:
    Structure is very simple, but here's the plans. So you don't need to think whole system by yourself.
    First picture is the part 1.
    Its made from three parts. 2pcs 30mm x 20mm x 3mm flat bar.( part 1.1 ) And one 20mm x 26mm piece of 10mm thick flat bar. (part 1.2 )
    Parts 1.1 are weld to parts 1.2 so that gap between parts 1.1 is 20mm ( same as the thickness of part 2 )
    Quick locking tilting angle grinder handle.-33037618_1941488139218123_7188053117647192064_o.jpg
    Second picture is the part 2.
    Its made from 30mm x 20mm flat bar. Cut to size 30mm x 20mm x 26mm
    20mm thick side goes between parts 1.1 in the part 1.
    Quick locking tilting angle grinder handle.-33143388_1941488175884786_871946809981796352_o.jpg
    Third picture is from the handle.
    I changed the srew from it to longer one. So that the lenght after locking nut is 20mm
    Quick locking tilting angle grinder handle.-33041396_1941488182551452_1830468731742978048_o.jpg
    Fourth picture shows the screws used for assembling.
    M6 screw. Lenght 35mm. Two 6mm washers and nylock nut to connect parts 1 and 2 together.
    10mm washer goes between part 2 and the grinder.
    Quick locking tilting angle grinder handle.-33216162_1941488219218115_4681975614947721216_o.jpg
    Simple idea, but works
    Attached Thumbnails Attached Thumbnails Quick locking tilting angle grinder handle.-fb_img_1526728002608.jpg
  2. The Following 18 Users Say Thank You to Tuomas For This Useful Post:
    bobs409 (May 19, 2018), carloski (Jul 1, 2022), emu roo (Nov 28, 2025), guitwar (May 21, 2023), hansgoudzwaard (Sep 27, 2018), Jon (May 19, 2018), LMMasterMariner (May 20, 2018), mr mikey (Nov 14, 2024), olderdan (May 21, 2018), Paul Jones (May 21, 2018), PJs (May 19, 2018), Ralphxyz (Nov 15, 2024), rlm98253 (May 15, 2023), rossbotics (May 19, 2018), Seedtick (May 19, 2018), sossol (May 20, 2018), Toolmaker51 (Jul 4, 2022), volodar (Jan 5, 2020)
  4. The Following 4 Users Say Thank You to Jon For This Useful Post:
    DIYer (May 24, 2018), emu roo (Nov 28, 2025), PJs (May 19, 2018), Tuomas (May 20, 2018)
    Jyväskylä Finland
    Tuomas's Tools
    ....and then there's all those belt sander, power file, router.. modifications too.
    Angle grinder seems to have endless possibilities, like hand drill also.
  6. The Following User Says Thank You to Tuomas For This Useful Post:
    Dec 2016
    Ralphxyz's Tools
    Nice project, I love that grinder.
    Ralph
  8. The Following User Says Thank You to Ralphxyz For This Useful Post:
    Jyväskylä Finland
    Tuomas's Tools
    Ralph
    Thank you Ralph!
  10. The Following User Says Thank You to Tuomas For This Useful Post:
  11. #6
    Jyväskylä Finland
    Tuomas's Tools
    Tried to add plans earlier, but i had some issues with Firefox, with Chrome picture uploading seems to work nicely.
    Now there's plans at the first post.
  12. The Following 2 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (Nov 28, 2025), PJs (May 24, 2018)
  13. #7
    Jyväskylä Finland
    Tuomas's Tools
    If Jon counted right? This should be 10th angle grinder add from me.
    Plate locks to the disc guards locking slots.
    Disc guard can be removed within 3 seconds, without tools.
    So, result should be a power file attachment that can be attached / deattached without tools in couple seconds.
    Shaped slots with hand files.
    Fits to the slots.
    Locked on simple turning it 90 degrees.
    More coming later...
  14. The Following 6 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (Nov 28, 2025), Gregraper33712 (May 24, 2018), Jon (May 24, 2018), PJs (May 24, 2018), Seedtick (May 24, 2018), will52100 (May 24, 2018)
  15. #8
    Thanks Tuomas! We've added your Angle Grinder Tilt Handle to our Miscellaneous category,
  16. The Following User Says Thank You to DIYer For This Useful Post:
  17. #9
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Me to on Firefox, don't use chrome if I don't have to. On Firefox if you use the "Basic Loader it seems to work, but limited to one picture at a time.
    Nice addition with the filer Tuomas! Got my eye on one of those Bosch Grinders!! Thanks Tuomas!!
    PJ
    Mark Twain
  18. The Following 2 Users Say Thank You to PJs For This Useful Post:
    emu roo (Nov 28, 2025), Tuomas (May 25, 2018)
  19. #10
    Jyväskylä Finland
    Tuomas's Tools
    PJ
    Thanks buddy. I have "allways" used firefox. I'll try that basic uploader next time.
  20. The Following 3 Users Say Thank You to Tuomas For This Useful Post:
    emu roo (Nov 28, 2025), Paul Jones (May 26, 2018), PJs (May 28, 2018)
