Results 1 to 10 of 14
Thread: R-8 Modular Gear Cutter Arbor
    Dec 2013
    Florida
    rossbotics's Tools
    In my last post I had built a dividing fixture for cutting some 3 Modular gears, I mentioned that I would post the arbor for holding the cutter when it was done.
    There was a lot of work making the indexing fixture and arbor but they came out very nice, Would had been a lot easier to buy a dividing head and be done with it, But that takes all the fun out of it, Besides isn't that what this site is all about ? Making tools and sharing ideas?
    The gears I'm making are a 3 Mod with 30 teeth which takes a number 5 cutter, Got 2 of those off E-Bay pretty reasonably priced.
    I'm making a total of 9 gears of all the same dimensions, I ganged up 3 at a time on the indexers mandrel and started making chips.
    Below are some photos of the arbor, indexer , and the gear teeth being cut on the mill.
    As always, thanks for looking and happy Machining
    Doug
    Above shows the arbor and it's components
    Above shows another view of the arbor , Note the spring loaded dowel pin which serves as keyway, being spring loaded allows me to mount any thickness cutter and have a full length for key driving the cutter, the arbor washer will push the pin into the reamed hole to what ever depth it needs to be.
    Another view
    Assembled
    Above shows all the tooling and 3 gear blanks
    Above shows the gear teeth being cut, The gears are made from 4140 annealed steel, After the machining is done the teeth will be heat treated
    Another view of the teeth being cut
    A view of the indexing arrangement on the indexer
    Comments are always welcome
    Doug
  2. The Following 10 Users Say Thank You to rossbotics For This Useful Post:
    backyard_cnc (Feb 9, 2016), basil3w (Oct 4, 2018), ChrisB257 (Oct 5, 2018), emu roo (Nov 13, 2025), kbalch (Oct 14, 2015), NortonDommi (Nov 22, 2017), Okapi (Jul 29, 2017), Paul Jones (Oct 14, 2015), PJs (Oct 14, 2015), Ralphxyz (Feb 27, 2024)
    Thanks rossbotics! We've added your Gear Cutter Arbor to our Machining category, as well as to your builder page: rossbotics' Homemade Tools. Your receipt:
  4. The Following 2 Users Say Thank You to DIYer For This Useful Post:
    emu roo (Nov 13, 2025), Okapi (Jul 29, 2017)
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    Nice work, well done
  6. The Following User Says Thank You to Ed ke6bnl For This Useful Post:
    Beautiful work on the Arbor, Doug! Thanks for sharing this and your gear cut with us also. Your projects are always a real inspiration!! Interesting that you gang cut the 3 gears, definitely would save time. They look to be about .75 thick each and the shaft on the indexer is 1"...any deflection or did you take multiple passes per tooth? Just a novice and was thinking about the 1.5D rule of thumb. Have an idea for something that uses a small rack and pinion and some concerns about holding the small rack vertically during cutting. Thanks again. ~PJ
  8. The Following User Says Thank You to PJs For This Useful Post:
    Dec 2013
    Florida
    rossbotics's Tools
    Thanks PJs
    There were no deflection in the mandrel at all. The gears were .787" thick. The outer diameter is 3.776". I took the whole depth of the tooth in one pass. The whole depth of the tooth is .266". I didn't have a problem at all.
    Thank you very much for your compliment.
    Happy Machining
    Doug
    Doug
  10. The Following 2 Users Say Thank You to rossbotics For This Useful Post:
    emu roo (Nov 13, 2025), PJs (Oct 14, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Hi Doug,
    More great work and photography! Your Gear Cutter Arbor is the 'Tool of the Week'!
    Since you've already received one of our official HomemadeTools.net T-shirts, we'd be glad to award you a $25 online gift card!
    Just let me have (via PM) your email address and we'll get things processed directly.
    Congrats!
    Ken
  12. The Following 3 Users Say Thank You to kbalch For This Useful Post:
    emu roo (Nov 13, 2025), PJs (Oct 16, 2015), rossbotics (Dec 1, 2017)
    Supporting Member backyard_cnc's Avatar
    Feb 2014
    backyard_cnc's Tools
    Great job, the need to index accurately just seems to come up so often in the shop that having multiple ways to achieve it is most useful.
    Gerald
  14. The Following User Says Thank You to backyard_cnc For This Useful Post:
    San DIEGO, California
    Captainleeward's Tools
    Doug, WOW that is some classy metal work there, I was thinking of buying the dividing plates for my rotary table now I am rethinking that idea .. :O)
  16. The Following User Says Thank You to Captainleeward For This Useful Post:
  17. #9
    Ralphxyz's Tools
    Doug, is that a cold air gun you were using to cut the gears? If so what do you think of the cold gun? Where else do you use it?
    Thanks for posting.
    Ralph
  18. #10
    Dec 2013
    Florida
    rossbotics's Tools
    No Ralph
    That's just a air coolant nozzle with soluble oil diluted, I just cleaned up everything before I took the pictures
    Thanks for asking
    Doug
    Doug
  19. The Following User Says Thank You to rossbotics For This Useful Post:
