Results 1 to 7 of 7
Thread: Rear Tool Post Spacer Block Sherline Lathe
Hybrid View
    jjr2001's Tools
    They say the Sherline Lathe is at it's best with a rear cutoff tool and I always wanted to try that on my mini lathe.
    So, I made a spacer block for the Sherline supplied front cutoff tool and got a longer hold down bolt for use on the rear of the cross slide table.
    Nothing special about this at all, just a 1/2" high block of aluminum with a hole in the right place. It is not in the center but offset.
    We won't know how this works for a while.
    Attached Thumbnails Attached Thumbnails Rear Tool Post Spacer Block Sherline Lathe-img_1954b-copy.jpg
  2. The Following 6 Users Say Thank You to jjr2001 For This Useful Post:
    Jon (Apr 28, 2018), olderdan (Apr 28, 2018), Paul Jones (Apr 28, 2018), PJs (Apr 30, 2018), rossbotics (Apr 28, 2018), Seedtick (Apr 28, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Lots of smaller machines with the cutoff tool mounted in reverse works better than the conventional method, eliminating chatter
    Comments are always welcome
    Doug
  4. The Following User Says Thank You to rossbotics For This Useful Post:
    jjr2001 (Apr 29, 2018)
    olderdan's Tools
    That should be a great improvement that set up works for me on my SB, is the reverse position just for the photo shoot?.
  6. The Following User Says Thank You to olderdan For This Useful Post:
    jjr2001's Tools
    I hope to have some material ready for my next model engine soon and then we will see how well it works on the Sherline.
    Cheers, JR
    I have a rear mounted tool post and I find parting to work about the same as when using the front one. No advantage nor disadvantage. I also have a 4 way indexable tool holder on that rear post which always has 3 tools mounted, 1. the parting tool, 2. a small drill chuck with a short spotting drill bit and a normal turning tool.
    The advantage that I find with the rear tool post is that I don't have to change tools on the front one as often and the permanently mounted spotting drill saves quite a few tailstock chuck and/or drill bit changes. Unless actually drilling for a centre I prefer a spotting drill to a centre drill for a pilot hole.
    Sometimes the rear post gets in the way on certain jobs but I made it to be removable quickly and I machined register surfaces so that it goes back into the same place when fitted again. I don't have to take it off often.
    jjr2001 (Apr 30, 2018)
  10. #6
    jjr2001's Tools
    Thanks for the info Tony, I did not think to put a 3 or 4 way tool holder back there. Could bring some extra versatility to the lathe.
    Cheers, JR
