Results 1 to 10 of 12
Thread: Recovering a "dead" lithium battery
Hybrid View
    Dec 2022
    Midwest US
    ductape's Tools
    It seems like a good idea for the battery management circuitry to just shut down and stop drawing power before the pack gets to the point where it can't be recharged with the normal method, then wake up when plugged in. I'm not an EE so may just be showing my ignorance.
  2. The Following 2 Users Say Thank You to ductape For This Useful Post:
    emu roo (Oct 14, 2025), nova_robotics (Oct 14, 2025)
    jdurand's Tools
    Quote Originally Posted by ductape View Post
    While true, that is not normally the case. Almost all battery packs use one of only a couple of different chips or the microcontroller in their product that also does other things. Essentially nobody has any incentive to do it differently.
  4. The Following 2 Users Say Thank You to jdurand For This Useful Post:
    emu roo (Oct 14, 2025), PJs (Oct 16, 2025)
    Sep 2018
    nova_robotics's Tools
    They do, but the problem is even the circuit to disconnect takes a tiny bit of current. A DW01 is a super common little low-voltage cutoff chip, and it's quiescent current (nerd speak for the amount of current something draws when it's off) is around 3 micro amps. So 3 millionths of an amp. Normally this is smaller than the self-discharge of the battery so we don't care. But it all adds up and eventually destroy the cell if you leave it long enough.
  6. The Following User Says Thank You to nova_robotics For This Useful Post:
    jdurand's Tools
    And it's even worse if they use their microcontroller in place of the DW01. I think that's the problem with the battery welder, they mention they have all sorts of over temp and over current protections for the battery. So, they probably do it all with their processor and that would be why this ran down in about 6 months.
  8. The Following User Says Thank You to jdurand For This Useful Post:
