Results 1 to 6 of 6
Thread: Recutting My Bandsaw’s Flip Up Table Blade Slot
Hybrid View
    Supporting Member will52100's Avatar
    Oct 2015
    Bassfield, MS
    will52100's Tools
    The only concern would be the JB letting go, but if you did the prep work rite then it should hold for that. I wouldn't worry about opening the slot up any, the blade will do that on it's own. I need to cut a new aluminum disk for my vertical bandsaw. It's got a cast iron table with aluminum insert for the blade area and after a number of years the slot is huge.
    courtneyknives.net
  2. The Following User Says Thank You to will52100 For This Useful Post:
    rgsparber (Apr 29, 2020)
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Quote Originally Posted by will52100 View Post
    You have given me a good "plan B". If the JB Weld doesn't hold, I can mill out a recess and make an aluminum disk with a slot in it. Since I often lift up the table, the disk would need to be secured.
    Thanks,
    Rick
    Rick
