Results 1 to 5 of 5
Thread: Reducing the jaw lift of a Wilton 11674 Vise for use on a mill
    jjr2001's Tools
    Well we will attempt to improve upon our first Wilton 11674 vise mod and see if we can reduce the jaw lift even more.
    Homemade Vise Lift Modification - HomemadeTools.net
    While it will not replace the Kurt vise on any large mill it will make a very nice addition to the Mini Mill.
    A Kurt or even Import milling vise dwarfs the mini mill and I have had good luck with my Wilton so far,
    just wanted to make it act like a Kurt...( A light weight Kurt that is) My alternate method on the mini mill is
    to use a 3" machinist vise that does not exhibit any up lift tendencies. (none that I noticed)
    A base plate was needed in order use the clamping groove in the vise for the lock down feature:
    http://www.homemadetools.net/forum/i...punching-65904
    Once this was installed the lock down clamps were made. Simple parts made of 1018 cold rolled.
    10-32 cap screws were used throughout. A small recess was milled in the side of the main clamp blocks
    to provide clearance for the vise base. (Vise jaw is not quite as wide as the base)
    Clamp down action is accomplished with the top cap screw on the left and right hand clamps.
    Yep, I know, not as convenient as the single screw Kurt but this vise is convenient to use on the mini mill
    and I feel that a full size lock down vise is just too big for my little mill. Two pins in each clamp guide the foot and keep it from twisting. Loctite was used on the main clamping block to secure the pins.
    I will be making some before and after tests on this setup tomorrow.
    Another vise addition for the Wilton was this thread with the vise stop:
    Homemade Milling Vise Stop - HomemadeTools.net
    And of course the soft jaws:
    http://www.homemadetools.net/homemade-vise-soft-jaws-12
ID:	21723   Click image for larger version.
ID:	21724   Click image for larger version.
ID:	21725   Click image for larger version.
ID:	21726   Click image for larger version.
ID:	21728   Click image for larger version.
ID:	21729   Click image for larger version.
  2. The Following 9 Users Say Thank You to jjr2001 For This Useful Post:
    Carnel (Jul 17, 2020), emu roo (Oct 28, 2024), high-side (Aug 1, 2020), Paul Jones (Jan 22, 2018), PJs (Jan 28, 2018), rlm98253 (Jan 23, 2018), Seedtick (Jan 23, 2018), sossol (Jan 24, 2018), uv8452 (Sep 1, 2025)
