Thread: Removing bad chuck from spindle
    hemmjo's Tools
    I got a nice 1/2" DeWalt corded hammer drill from a dumpster on a site I went to do some service work. The chuck was bad, but they are "easy" to change , right? HA!!!
    I tried all of the standard, and a few not so standard ways to remove the bad chuck. A this point I knew why it had been discarded. I had seen a concrete contractor toss it into the dumpster, I assumed the chuck was rusted onto the spindle. I also could not remove the left hand locking screw from inside the chuck.
    With nothing to loose, I drilled the head off the left hand screw, still could not get the chuck to move.
    I ended up removing the spindle chucked it up in the lathe and carefully turned the chuck into chips.
    All that remained of the chuck was the threads.
Name:	drill spindle 1.png
    It became obvious someone had used RED locktite to secure both the chuck and the retaining screw.
Name:	drill spindle 2.png
    The spindle threads are perfect, ready for a new chuck.
  2. The Following 5 Users Say Thank You to hemmjo For This Useful Post:
    Home-PC (Sep 7, 2022), metric_taper (Sep 6, 2022), nova_robotics (Sep 6, 2022), Scotty1 (Sep 5, 2022), uv8452 (Sep 6, 2022)
