Results 1 to 10 of 30
Thread: Repairing Nicked Extension Cords
  1. #26
    Rikk's Avatar
    Nov 2018
    Rikk's Tools
    Just to add to the data here for anyone searching...
    When I have an electrical joint, usually 12v on a truck, motorcycle or especially a race car, I try to use the Grote brand, dual wall, 4:1 heat shrink tubing with adhesive inside.
    I will always put one length of tube, extending a reasonable amount over the spice, then a second layer extending beyond the first. The heat melt glue inside the tubing seems to hold up to about anything and rarely fails. The 4:1 ratio allows plenty of room so you can use the same size tube for both.
    Sometimes, when it's late in the evening or I run out mid-job, I will brush on a significant amount of liquid electrical tape, then position normal heat shrink tube, working it back and forth so the liquid extends beyond the joint then apply heat. Followed by a second layer repeating the process. 20 years ago I used this to repair a dirt bike wiring harness that was snagged on a branch and torn in half. I still ride the bike regularly and have zero problems.
    Both of these seem to work about the same, but the Grote tube with adhesive is MUCH cleaner.
  2. The Following User Says Thank You to Rikk For This Useful Post:
    Toolmaker51 (May 18, 2021)
