The use of resistors in this situation is called a "shunt"
Another method for measuring high current draw is to measure across the supply lead that oft times goes from the power source directly to the load. Disconnect, and, accurately measure the resistance of that lead, and you have a "known" shunt value. Reconnect, and then measure the current draw and you achieve the same result
Cheers Phil
