Results 1 to 8 of 8
Thread: revolving two tire lift
Hybrid View
    Stockholm, Sweden...
    DIYSwede's Tools
    Nice idea and probably a good market concept - good luck with your patent!
    IMHO it looks like two 200 W worm drives (of which I have quite a few, and use for workshop tables and hoists),
    working thru toothed belt drives, where the batteries and control boxes are under the side support covers?
    Back in 1977-78 I worked extra at a truck, equipment & auto tire shop/ retreading facility, where we used in-house built,
    rugged, hand-wound Truck wheel "forklifts" for the same purpose, albeit not with your 2-tire, revolving capacity.
    Just stickwelded hot rolled RHS and U-beams, some sealed ball bearings for the moving platform,
    cast pulleys, 8" 500lbs SWL castors and a locking hand winch.
    All covered in the company's hideous, undescribable blue-green bile enamel.
    These were self-explanatory, easy to use, lo-maintenance, easily hosed off friday afternoon and dirt cheap.
    The following is not intended as criticism, though I realize it could be perceived so:
    Two (totally uncalled for) cents regarding your device:
    -What'll happen when dust, grit, grime, salt and sleek from the wheels & shop enters the mechanism:
    especially between the bottom drive pulleys and belts,
    and what do the slide's bearings consisting of? Sheets/ rollers of acetal?
    Feel free to give further info on materials, battery/ motor capacity, max SWL etc.
    Cheers
    Johan, (who isn't "into rubber" any longer.)
