Results 1 to 10 of 13
Thread: RGN trailer neck rebuild
    Me and a friend of mine bought a 2 axle RGN trailer with a 3rd flip axle about a year ago then sold the flip axle for nearly as much as we paid for the trailer. So it came down to either scrap it for about as much as we sold the flip axle for or rebuild the neck then determine how much we want to spend on the trailer itself
    What it started out as
    some of the scrap removed
    nearly 400 lbs of rust was beat off with a needle gun
    more rust removed chemically
    wrapped in plastic to allow the chemical to work over night
    rolling 2 pieces of 3/8x 4 1/2 T1 steel in my homemade plate roll
    strapping the neck
    Making cardboard patterns for the webs
    webs welded in place
    installing replacement king pin and plate
    ready to go back together
    new cross members and side rails
    web stiffeners for D rings
    Welds in slots cut through side rails
    D ring mounts welded over slot welds tying the loop to the stiffener
    ground sanded washed with a solution ready for rinsing drying and painting
    first coat of paint after being dusted with an etching primer for the hard to reach areas is could not sand very well
  2. The Following 8 Users Say Thank You to Frank S For This Useful Post:
    baja (Sep 21, 2021), clydeman (Sep 20, 2021), Jon (Sep 23, 2021), mwmkravchenko (Sep 22, 2021), NortonDommi (Sep 20, 2021), sak778 (Sep 24, 2021), sossol (Sep 26, 2021), Toolmaker51 (Sep 21, 2021)
    Thanks Frank S! We've added your Trailer Neck Rebuild to our Trailers and Towing category,
    Well I now have the final color on the neck and it is so yellow it hurts my eyes and my camera to look at
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Wow! I know a guy that dipped an entire mini body in acid to lighten it for a race car he was building but leaving something to rust and then knocking the rust off, Brilliant! No hydrogen embitterment from the acid reaction either.
    Pure genius Frank, pure genius. Learn something new everyday.
  7. The Following User Says Thank You to NortonDommi For This Useful Post:
    Frank S (Sep 20, 2021)
    Supporting Member toeless joe's Avatar
    Oct 2019
    Denver,CO
    At least you won't forget where you parked it. Just look for the yellow glow.
    We NEVER saw anyone weld cardboard before!
  10. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  11. #7
    you got to be good and have the right filler rods
  13. #8
    Perth Ontario Canada
    Safety yellow.
  14. #9
    And of course, the corrugations being vertical, have greater strength against the load on the neck.
    Nothing comical regarding filler rods comes to mind, including drinking straws and stir sticks...
    In other news, assembling a stack of cardboard storage bins here in Anaheim for my protege. I should rustle up a hot melt glue gun and weld inner corners and tabs, beefing up life span.
  15. The Following User Says Thank You to Toolmaker51 For This Useful Post:
  16. #10
    Oct 2015
    I am all for paint things with safety yellow. I attached a couple of pictures of the things I build. They are painted safety yellow. I tell the customer that he can put them away and never loose them. lolRGN trailer neck rebuild-0913181422a.jpg
  17. The Following User Says Thank You to bwpigeon For This Useful Post:
    Toolmaker51 (Sep 28, 2021)
