Results 1 to 6 of 6
Thread: Rockwell Sander Restoration
    Dec 2013
    Florida
    rossbotics's Tools
    I got this sander a while back and just now decided to do something with it, I'm working on a couple of tool designs but decided to tackle this time consuming task before I got machining on my next tool, I should have this next tool done in a couple of weeks, I been looking at this sander sitting all by itself in the corner for quiet sometime so I went for it and did it, man am I glad that's over.
    Had to fabricate a few parts such as the table support brackets, a belt guard, the belt tensioning adjuster, all new stainless steel hardware, belt, bearings and cast iron pulleys.
    All and all I think it came out pretty good, if you compare it to what it looked like before.
    Below are some photos of before and after
    As always
    Thanks for looking and happy machining
    Doug
    Before
    Before
    After
    After
    After
    After
    Comments are always welcome
    Doug
  2. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (May 25, 2016)
    Very nicely done I used to have one of those 12" disc sanders with the 6 by 48" belt If I remember correctly mine had a 3 HP 3 ph motor
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Oh My, Doug. You turned the beast into a beauty!! Terrific restoration is an understatement. I noted you left off the protractor off the new brackets. Do you mainly use it at 90º or use a digital angle finder? Thanks for sharing the great pictures and build. ~PJ
    Mark Twain
    Dec 2013
    Florida
    rossbotics's Tools
    Thanks PJs
    I mainly use it 90°, The other side to the table protractor was broken so I just made it a permanent 90°, works fine for me
    Thanks Guy
    Doug
    Doug
  6. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (May 25, 2016)
    Apr 2016
    Well, there goes the patina...
    A beautiful job, and one that shows the skill and the patience of the craftsman. I hope you post images of future projects.
    Eamon
    Thanks rossbotics! We've added your Sander Restoration to our Miscellaneous category,
    as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
