Results 1 to 7 of 7
Thread: Rotary broaching tool.
    Berkshire UK
    thehomeengineer's Tools
    Hi All
    i don’t normally make a tool if I haven’t got a job for it but I am fascinated by rotary broaching. Anyway cutting a long story short I have made one and am very pleased with the results so thought I would share with you the build. I bought the bearings, tab washer, locking nut and two arbours (R8 and a 3MT).
    Before I get on to the build I will try and explain how rotary broaching works and what it is used for.
    Rotary broaching is a form cutting process and both internally and externally forms can be produced using this technique. (I am interested in internal forms) Examples of forms are squares, hexagons and splines which can all be produced.
    The broaching tool body has the internal shaft supported on bearings angled at 1 degree angle which obviously allows the tool to run off centre (a bit like a drill that hasn’t been correctly placed in a chuck and then runs out). As the cutting tool is in a housing supported on bearings the tool, when it comes in to contact with the work piece stops rotating with the spindle but moves in a oscillating motion and this action allows the corner of the tool to cut the form of the cutter in a pre-drilled hole.
    A tool needs to be made with the desired shape and size to be cut. When grinding the cutting tool flanked clearance is needed at approximately 2 degrees for clearance and the bottom of the tool relieved to give a sharp cutting edge.
    One drawback is the cutting tool needs to be positioned at a known distance from the centre of the broaching body centre line to allow the cutter to produce the correct size.
    I hope the photos will clarify my explanation on how the tool works.
    Material and purchased items
    centring work piece
    Main body set at 1 degree
    machining location tongue
    Tool shaft
    Truing the outer body in the lathe so this runs concentric to the main spindle. The internal bearings and tool shaft maintain the 1degree angle to allow too to oscillate.
    machining shanks for c-spanner
    Shaft screw cut for purchased bearing locking nut.
    Internal shaft thread and machined to accept locking tab washer.
    The thin bee-blocks make it easy to clock to find the centre. Link to vee-blocks Story of the little discarded beat up Vee block
    grease hole for bearings sunken in to body to avoid nipple protruding outer body.
    completed parts ready for assembly
    Completed body
    Cutting tools from old slot drills
    3/16” hexagon in steel
    Aluminium
    Thank you for viewing
    The Home Engineer
    Attached Thumbnails Attached Thumbnails Rotary broaching tool.-94a50fa7-842f-4a84-8b64-fe9a80f0a204.jpeg   Rotary broaching tool.-fae38497-8130-4422-9fe3-4a7c0347aea3.jpeg   Rotary broaching tool.-67e38ec5-5c8e-4703-b3b0-3a2366643d7f.jpeg
  2. The Following 16 Users Say Thank You to thehomeengineer For This Useful Post:
    BrianW (Mar 30, 2020), emu roo (Feb 21, 2026), Hopefuldave (Mar 28, 2020), HUMARIA (Apr 5, 2020), Jeff Michel (Mar 31, 2020), Jon (Apr 2, 2020), mr herb (Mar 31, 2020), mrsuwds (Apr 23, 2020), mwmkravchenko (Mar 30, 2020), NortonDommi (Apr 3, 2020), Philip Davies (Mar 28, 2020), Rikk (Mar 31, 2020), Sleykin (Mar 30, 2020), threesixesinarow (Apr 4, 2020), Toolmaker51 (Jul 31, 2022), Tule (Mar 31, 2020)
    Thanks thehomeengineer! We've added your Rotary Broaching Tool to our Machining category,
    Supporting Member celsoari's Avatar
    Jan 2018
    Brazil
    celsoari's Tools
    nice working
  6. The Following 3 Users Say Thank You to celsoari For This Useful Post:
    emu roo (Feb 21, 2026), JoeH (Mar 31, 2020), thehomeengineer (Mar 28, 2020)
    Dry Gulch, Tx
    Crusty's Tools
    You can easily add rake to the cutting edges by mounting your tool in the lathe chuck and a Dremel on center in your tool post with a cutting wheel attached. Bring the wheel edge on up to the spinning cutting tool, ease into it and you will surprisingly quickly grind out a hemispherical depression in the end of the cutting tool, providing a small amount of rake to your cutting edge. They broach better with some rake.
  8. The Following 3 Users Say Thank You to Crusty For This Useful Post:
    emu roo (Feb 21, 2026), mr herb (Mar 31, 2020), thehomeengineer (Mar 28, 2020)
    Berkshire UK
    I have added a short video of the tool working
  10. The Following User Says Thank You to thehomeengineer For This Useful Post:
  11. #6
    Aug 2016
    wizard69's Tools
    thanks for the post
    Quote Originally Posted by thehomeengineer View Post
    Thee are many approaches to these homemade rotary broaches and this one highlights an important idea, use pre-made arbors. Why I never considered that I don't know but it makes perfect sense, especially if you might be moving the broach between a mill and drill press.
    I have to ask do you have info on the bearings used in this build? One looks like a Timken style bearing.
  12. The Following User Says Thank You to wizard69 For This Useful Post:
  13. #7
    Berkshire UK
    Hi Wizard69
    My intention is to make the drawings available and free on this site but unfortunately this won’t be any time soon as the drawings are at work and is lockdown. However the bearings are 30203 and 6003 and locking nut KM3 and tab washer MB3. The arbours are 1” 1/2 x 18TPI. R8 and No. 3 morse taper and a couple of 6mm grub screws and M4 cap head screws, grease nipple. These are the purchased items roughly £45 in total. Two pieces of 70mm diameter steel and 20/55 long and a piece 30mm diameter 50mm long.
    hope this helps you at the moment
    The Home Engineer
  14. The Following User Says Thank You to thehomeengineer For This Useful Post:
