Thread: Rotary four wheel attachment for 2"x72" belt sander/grinder
    New Lenox, IL
    garycullen's Tools
    I made a rotary 4 wheel turret for my 2" x 72" belt grinder. It uses 3",4" 6" and 8" x 2" wide wheels. Instead of 4 separate arms for each wheel it uses only ONE ARM!. It is 6-1/2" wide and the pivot is in the exact center and all 4 wheels are the same distance from the edge of the pivot arms. I set the distance for each wheel using a telescoping gauge. When you change to a different roller the belt lines up exactly. I didnt even have to adjust the tracking for any of the rollers whether on one side or pivoted to the other side. I also made the pivot on the side arms offset, so when you go from one roller to the other you don't have to adjust the arm a lot to tighten the belt.
    Rotary four wheel attachment for 2"x72" belt sander/grinder-img_1475.jpggary.cullen@att.netRotary four wheel attachment for 2"x72" belt sander/grinder-img_1476.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1477.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1478.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1479.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1480.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1481.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1483.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1484.jpgRotary four wheel attachment for 2"x72" belt sander/grinder-img_1486.jpg
  2. The Following 11 Users Say Thank You to garycullen For This Useful Post:
    bvd1940 (Nov 28, 2017), CharlesWaugh (Feb 28, 2023), cwdettloff (Apr 21, 2018), emu roo (Jun 20, 2025), galebars (Nov 28, 2017), high-side (Jan 5, 2020), Jon (Nov 27, 2017), NortonDommi (Nov 28, 2017), Scotty1 (Mar 1, 2023), Seedtick (Nov 27, 2017), Toolmaker51 (Feb 28, 2023)
    Oct 2014
    W. WA
    Eagle_view's Tools
    Great Project and idea. Thank you for sharing
  4. The Following User Says Thank You to Eagle_view For This Useful Post:
    emu roo (Aug 27, 2025)
    New Lenox, IL
    garycullen's Tools
    Quote Originally Posted by Eagle_view View Post
    Thank you, I appreciate the comment
  6. The Following User Says Thank You to garycullen For This Useful Post:
    Thanks garycullen! We've added your Belt Sander Attachment to our Metalworking category,
    as well as to your builder page: garycullen's Homemade Tools. Your receipt:
  8. The Following User Says Thank You to DIYer For This Useful Post:
    Brilliant addition! Great as long narrow-belt sanders are, the real benefit is blending corners and hollow grinding flats. Being able to change radius? Wow.
  10. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Supporting Member CharlesWaugh's Avatar
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Beautiful!
    Download plans for belt sanders and grinders.
    Charles Waugh
    www.charleswaugh.com
    "Any tool is just a kit, to be modified as needed for the job at hand"
  12. The Following User Says Thank You to CharlesWaugh For This Useful Post:
