Thread: Sacrificial drilling fixture out of OSB and a 2by4
    I find the best way for me to cut holes in thin materials is to clamp them between 2 pieces of wood as a sacrificial drilling fixture
    In this case I need to drill 2 sized holes in the brass shim stock
    First the small hole
    then the large hole and drill through the stock to create the part
    Since I needed multiples of what I was making in 2 sizes after making the large diameter shims
    I changed the 3 1/2" hole saw out for a 2 1/8" so I could make 2" shims
    Now drilling up from the bottom the 2/4 becomes the guide for the 3/4" hole saw
    I then finish off by using the 3/4" hole in the shim and the 2x4 as the guide for the 2 1/8" hole saw
    Large & small brass shims plus a bunch of 1/4" brass washers as an added benefit, with a couple of OSB disks thrown in for good measure
    baja (Apr 15, 2022), KustomsbyKent (Apr 15, 2022), nova_robotics (Apr 14, 2022), trevor_60_r (Apr 16, 2022)
