If you are being serious, First you push the end of the hose as deep as possible into the container you want to siphon from holding your thumb over the end and pull a short distance from the container, lift your thumb slightly to break the seal as you rapidly push the hose back into the container then immediately press your thumb back on the end of the hose, repeat the process as often as necessary to cause the fluid to reach your thumb. Hold the thumb closed-end below the intake end and release your thumb the fluid should flow freely.
I've always given it a suck it a see approach. I'll try the thumb method. It's got to taste better that's for sure.
