Results 1 to 10 of 28
Thread: Shop Built Angle Plate
  1. #6
    May 2012
    Byron, Michigan
    astroracer's Tools
    Thanks Al. I worked on it for about 4 hrs last night. I got the pocket in the top plate milled out for the hinge block and the hinge holes drilled.
    Added pics from 06ja16.
    I also made the hinge block and got that drilled and tapped for the mounting bolts. i could have made this out of some 1/2" key stock but I LOVE offhand cutting on the VBS.
    Marking the holes in the hinge block after fitting it to the notch in the top plate.
    i used a .25 dia. transfer punch to mark the holes in the hinge block.
    Mark
  2. The Following 3 Users Say Thank You to astroracer For This Useful Post:
    Altair (Jan 7, 2016), emu roo (Nov 19, 2025), mr mikey (Apr 12, 2023)
