Thread: SHORT CIRCUIT PROTECTION
    Feb 2019
    mariost's Tools
    An easy construction to protect our devices from short circuit damage. Here I use a 12 V 16 A relay for 12 V input voltage.
    You can also use a 5 V or 24 V relay if the input voltage is 5 or 24 V.The max current of the relay depends on the external electric load we connect to the output. Don' use Pb batteries as a supply. It is dangerous to burn the device. I also suggest to connect an external fuse before the device in case that something went wrong to protect the pwer supply (if it doesn' t have an internal automatic cut switch).
    You can watch the construction and the use here:
    Attached Thumbnails Attached Thumbnails SHORT CIRCUIT PROTECTION-f1.jpg   SHORT CIRCUIT PROTECTION-f2.jpg   SHORT CIRCUIT PROTECTION-f3.jpg   SHORT CIRCUIT PROTECTION-f4.jpg   SHORT CIRCUIT PROTECTION-f5.jpg
    SHORT CIRCUIT PROTECTION-f6.jpg   SHORT CIRCUIT PROTECTION-f7.jpg   SHORT CIRCUIT PROTECTION-f8.jpg
  2. The Following 3 Users Say Thank You to mariost For This Useful Post:
    Jon (Oct 1, 2020), nova_robotics (Sep 24, 2020), rlm98253 (Sep 24, 2020)
    Thanks mariost! We've added your Short Circuit Protection Box to our Electrical category,
    as well as to your builder page: mariost's Homemade Tools. Your receipt:
