It’s a cheap angle grinder. I replaced the right angle housing and gears with an endcap and a shaft extension.
It’s a lot bigger than the 90 watt original motor but the quill spring still lifts it easily.
Attachment 28810
Attachment 28810
I made a new base for the drill. It’s just plywood and works more or less the same as the old one but is easier to use and can be placed in more unusual ways.
The enclosure houses a cheap ac motor speed controller and a dc power supply for the magnet, each with an independent switch. The electromagnet is from a microwave oven transformer.
Attachment 39744 Attachment 39745
Attachment 39746
Thanks threesixesinarow! We've added your Magnetic Drill Press Base to our Drilling and Drill Presses category,
<div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="https://www.homemadetools.net/homemade-magnetic-drill-press-base"> <img src="/uploads/249366/homemade-magnetic-drill-press-base.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="https://www.homemadetools.net/homemade-magnetic-drill-press-base">Magnetic Drill Press Base</a> <span> by <a href="https://www.homemadetools.net/builder/threesixesinarow_2">threesixesinarow</a></span> </div> <div class="tags">tags: <a href='https://www.homemadetools.net/tag/drill-press'>drill press</a>, <a href='https://www.homemadetools.net/tag/magnet'>magnet</a>, <a href='https://www.homemadetools.net/tag/base'>base</a>, <a href='https://www.homemadetools.net/tag/controller'>controller</a> </div> </div> </div> </div>
