Results 1 to 10 of 15
Thread: Small angle/sine plate
    olderdan's Tools
    I needed a small adjustable angle plate to fit on my lathe crosslide and vertical slide for a project that requires accurate angles. This is only 4 inches square and was made from the last pieces of steel plate from my scrap box, hence the extra filled holes which I can live with. There is some pitting in the working faces but they have been scraped flat to a surface plate.
    Although I have a Moore & Wright vernier protractor which gives 5 mins of angle, just out of curiosity I thought I would provide a sine function to the plates by virtue of a dowel exactly 3.25 inches from the pivot point and of the same diameter which fortunately has turned out to be accurate from my checks with the protractor and a 30 deg angle gauge. This could be a way to make a sine table for those without access to a surface grinder.
    As it is a small plate I opted for M5 clamp screws instead of my usual M6 and made some dedicated clamps. It pivots on hollow hardened pins and being a small surface I could not afford the support plates to be above the surface, so curved arms made from brass sufficed giving 0 to 45 deg. There is not enough room for a fence to be added so 2 location pins can be used to support a parallel when needed. This plate can also be used on the lathe faceplate for indexed milling using my live toolpost spindle, its not pretty but it will do the work I need it for.
    In this size it is more suited to a model engineer but could be scaled up if one has the material available.
ID:	22901Click image for larger version.
ID:	22902Click image for larger version.
Name:	Post plate.jpg
ID:	22903Click image for larger version.
ID:	22904Click image for larger version.
    I even found an empty router bit box to keep it all in.
  2. The Following 13 Users Say Thank You to olderdan For This Useful Post:
    G.Paul (Mar 28, 2018), Home-PC (Sep 4, 2020), Jon (Mar 28, 2018), Karl_H (Sep 1, 2020), LMMasterMariner (Mar 28, 2018), marksbug (Aug 1, 2018), Paul Jones (Mar 28, 2018), PJs (Mar 28, 2018), rossbotics (Mar 28, 2018), Seedtick (Mar 28, 2018), semaur (Sep 2, 2020), tonyfoale (Mar 29, 2018), Toolmaker51 (Aug 2, 2018)
