Results 1 to 8 of 8
Thread: Small tool rest
    France, Brittany !
    Christophe Mineau's Tools
    Small tool rest
    Hi,
    As said with the Doc, I have made also a small size tool rest for my wood lathe, more suitable when turning small pieces like pens, than the long 30cm rest.
    Its' a piece of flat steel inserted in a slot cut at an angle in a metal tube and brazed.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 2 Users Say Thank You to Christophe Mineau For This Useful Post:
    Doc (Feb 10, 2015), kbalch (Feb 11, 2015)
    Feb 2013
    South of Brazil.
    Hotz's Tools
    Very good...
    Sorry my mistakes in english.
    Doc
    Doc is offline
    Supporting Member Doc's Avatar
    May 2013
    Doc's Tools
    Very professional looking build there Christophe.
    Love anything we can make ourselves. Envy those who do it so well though
    Regards
    Doc
    France, Brittany !
    Thanks to the bad photos, you do not see the brazing details, not sure it's so professional ...
    One drawback also is with that soft tubing, the pressure screw on the side as a tendency to mark the steel and the rotation and setup became not as smooth as at the beginning.
    Solid steel would be preferable (but I couldn't find something with that diameter)
    Cheers !
    Christophe
  6. The Following User Says Thank You to Christophe Mineau For This Useful Post:
    Doc (Feb 11, 2015)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Christophe! I've added your Lathe Tool Rest to our Metalworking category, as well as to your builder page: Christophe Mineau's Homemade Tools. Your receipt:
    Mar 2014
    Newcastle
    Quote Originally Posted by Christophe Mineau View Post
    That's a good looking rest - better than my effort which ended up in the scrap bin. You could turn a piece of hardwood the same diameter as the tube and push it in to make it solid enough for your toolpost.
    That's what I did and it was OK - the problem was with the angle of the tool rest.
    Hope that helps.
    Ken
    France, Brittany !
    Thanks Ken, Yes that's a good idea to fill the tube with wood, I could also poor in hot lead.
    But actually, the tube walls are thick enough, it keeps round, but the steel surface is marked and not smooth, so that it does not turn smoothly, but that's not a big issue, I file it from time to time, and that's OK.
    Ideally, it would be better with some kind of surface heat treatment, but ...
    Cheers !
    Christophe
  10. #8
    Way to make use scrap steel.
